Previous Thread This topic has been viewed 1675 times and has 2 replies Next Thread
rulllesss
Ukraine
Custom roof. Tutorials do not help.
Hello,
I'm new to Sweet Home 3D, but find it quite useful.
I have been trying to build a roof. I went through some videos and samples how to build custom roof from walls (then export to obj and import as furniture)
The problem is that one part of the roof can be be build from either rectangular triangle (slooping wall) or rectangle (simple wall). What I need is parallelogram.
Pleae look at the image
here is where I stucked
Could you suggest how can I get parallelogram (which can not be done as 2 rectangular triangles) ?
[Mar 20, 2018, 8:57:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Custom roof. Tutorials do not help.
Hello,
Maybe you could try the Shape Generator plug-in available here.
You can also create a dummy room at an upper floor, export it at OBJ format and import the generated file, or use a box + 2 triangles.
[Mar 21, 2018, 9:48:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rulllesss
Ukraine
Thanks a lot. That helped!
[Mar 25, 2018, 11:58:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
