Previous Thread This topic has been viewed 2531 times and has 2 replies Next Thread
mctown
canada
round house
trying to make a simple round house,cant seem to figure this thing out! ugh
[Mar 1, 2018, 1:14:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: round house
If round walls are the problem, try thinking two half circles for the outer walls. Use wall tool and
- place cursor to the left, click and pull a wall to the right side of the circle,
- use CTRL-click to finish the wall, (enter lets you write in 180 degree arc),
- continue back to staring point, CTRL click again.
You can also enter/adjust the arc in the modify walls dialogue after you have created the walls.
You cannot draw round floors manually, but if you double-click with room tool inside a room, the room will follow also the round walls.
Windows can be a bit tricky as they do not align normally, but you can find some tests in SF 3d models 295. For roof, search the web, or look in SF 3d models 330.
[Mar 1, 2018, 12:40:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: round house
Tell us more !
Here some links with rounded houses made by myself which could inspirate you.
1. http://www.sweethome3d.com/support/forum/viewthread_thread,7097_offset,190
2. http://www.sweethome3d.com/support/forum/viewthread_thread,7427_offset,20
3. http://www.sweethome3d.com/support/forum/viewthread_thread,6914_offset,0
[Mar 2, 2018, 7:19:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
