Re: Windows 10 display issue
Could you try to reinstall the program using the options described here?
Also having this issue and nothing from what is mentioned here helped. Tried portable, tried jre 1.6, tried sh3d version 3.4, tried disabling java3d by env. variable (now causing directX/opengl error at start up). Issue starts right away when any tooltip appears, then it feels like re-paint is totally messed up (almost like double buffer content is painted where your mouse is). Found also other SW with similar reports: https://github.com/chatty/chatty/issues/69
My setup is Win10, 64-bit, Asus G752, Nvidia GTX1070, factory drivers
From version 6.0, the destination folder screen in Sweet Home 3D installer shows Architecture options to install the program in 32 bit or 64 bit. Did you try the 32 bit option?
