Re: Sweet Home 3D 5.5
Thanks for posting these videos. Really strange issue that I still can't reproduce under macOS 10.10 and 10.12 If needed, all installers are available here so maybe, you're not obliged to go back to such an old version. Could you try to install Java 8 and run Sweet Home 3D 5.5 from its Jar Executable or Java Web Start versions?
On the Online version, these features are available in the contextual menu of the 3D view once you logged in.
Could you try again with the Online version after you activate Java console? If some text appears when you try to create a photo, I would be pleased you copy paste it here to help me understand what's going on.
Thanks for this helpful information. The error must be provoked by the fact that you use two monitors on your computer. I made the required change in source code to fix this bug. Too bad, I didn't fix it with the update I published on Saturday, moreover because you reported it on Thursday Shall I release a version 5.5.2 already?
