Re: Sweet Home 3D 5.5
I'm sure your karma is ok, but mine is in bad shape for this release, even if regressions are unfortunately very difficult to avoid after programming important changes.
At least, printing and print preview work for the 3D view, and creating images work if you turn off the second monitor. As the users with two monitors who want to create pictures in quality 1 or 2 might be quite rare, I might wait longer before releasing a new version. I fear that the upcoming macOS High Sierra might require some more important changes if Apple doesn't fix the current issues with Java programs (in the current beta, Sweet Home 3D free DMG version doesn't work and the paying version has some problems with the menu bar). So I would prefer not to release a new version each week!
[Edit 1 times,
last edit by Puybaret at Sep 11, 2017, 3:54:33 PM]
In case of need, I published a patch for this issue that was reported by another user. See Bug #780.
Unless you speak Ukranian, Slovenian, Slovakian and Korean and translate all the new words tonight in those languages, you'll have to wait a little longer. I don't know if translators will agree to continue their contribution to Sweet Home 3D translations for this version, but I feel we shouldn't stress them and wait their contribution a little longer, no?
Why its not possible to edit my own posts, at least for a few minutes ? Thats a security problem, If somebody post wrong things, not for public.
What I wanted to ask you, too - why there is a difference between full installer an the portable version relating to the language translation ? The full installer is available in german.
I tought it was a bugfix release
Hum, you should look closer. The version 5.5 is much more than a bugfix release!
Why its not possible to edit my own posts, at least for a few minutes ? Thats a security problem.
You're right, it's for security reasons but not the ones you had in mind. It's mainly to avoid spammers to publish nice messages then change them once moderated. Forums are nice but they require some moderation work as soon as they are successful.
But be patient, let's hope that more translation updates will arrive soon.
I released tonight the version 5.5.2 which fixes some bugs reported since version 5.5 and includes the portable version.
To ensure Sweet Home 3D can run under the upcoming macOS 10.13 High Sierra, I had also to update the Java 3D version used in the installer (DMG) and portable distributions, to Java 3D 1.6.0 (the same one used under Java 8). Unfortunately, this obliges to give up support to Java 5 and PowerPC which are the only option to run Sweet Home 3D for some users under Mac OS X 10.4 and 10.5. Nevertheless, if these few users still want to use the latest version of Sweet Home 3D, they can still run the JAR Exectutable distribution. Anyway, keep in mind that giving up support to Java 5 will happen sooner or later because the compiler of upcoming Java 9 won't be able to generate files compatible with Java 5 anymore (for Java programmers, the smallest value for -target option in javac is 1.6 in Java 9). But there's no need to hurry! Speaking about Java 9, note that I also tried successfully Sweet Home 3D with the last Beta of Java 9 under Windows and Linux, but had trouble under Mac OS X, where it doesn't run yet (except if you use the -Dcom.eteks.sweethome3d.no3D=true Java option to run the program as Sweet Home 2D).
One last thing: there's still a bug in macOS High Sierra that prevents to display the menu bar of Sweet Home 3D at the top of the screen on non-English systems. In version 5.5.2, I programmed a workaround that attaches the menu bar at the top of each window (like under Windows), and as soon as Apple will have fixed this bug, the menu bar should go back to screen top. Please, don't beat me, I really did all my best to avoid this bug!
Hope you'll enjoy this update
[Edit 1 times,
last edit by Puybaret at Sep 21, 2017, 8:31:13 AM]
COPY-PASTE doesn't work under Mint 18
I made a drawing (walls and floors) and then tried to copy everything from level 1 to level 2. Unfortunately that wasn't possible. - I tried CTRL-A then CTRL-C then CTRL-V without success. - I tried select with mouse, then using the menu Copy and Paste without success.
Copy-Paste only works when selecting one or more items (but not ALL) at a time and copy-paste it to the new level.
NB: this is about walls and floors only, it's a design so far without furniture.
System: Mint 18, based on Ubuntu 16.04, SH3D version 5.5a
[Edit 1 times,
last edit by hansmex at Oct 26, 2017, 4:50:49 PM]
