Total posts in this thread: 241
Posts: 241   Pages: 25   [ Previous Page | 5 6 7 8 9 10 11 12 13 14 | Next Page ]
Previous Thread This topic has been viewed 971202 times and has 240 replies Next Thread
I have tested, and tested, and tested again, and again, and I have found nothing wrong.
PVR-1.8_betaTest2, in companion with Additional Sunflow options (v1,2), works like a charm, and the combination is surely a blessing for everyone concerned with advanced rendering.
Myself, I would rather that the semi-transparent part of an uncompleted rendering could be completely transparent, but it works perfectly well like it i is!
In my opinion, PVR-1.8_betaTest2 is a release candidate (if it hasn't already been released without my knowledge)
Thank you for your great work!
Cecilia
[Edit 1 times, last edit by Ceciliabr at Sep 25, 2019, 9:51:39 PM]
[Sep 25, 2019, 9:49:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
waleedfahmy
Egypt
I wish if one of experts make a detailed tutorial about rendering and setting . I get good results but after many trials and not totally satisfied with results
[Sep 25, 2019, 11:49:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@Ceciliabr
Regarding the problem of video rendering, everything works correctly?
On my side it's random for a new simple project: a single object and a linear or circular camera path.
It is possible but I did not propose it because we do not see the size of the image.
If everything is good on your side, I think that version 1.8 will soon be published.
The next big innovation will be the addition of the YafaRay rendering engine when its beta phase is over.
Enko
EnkoNyito
[Edit 1 times, last edit by enkonyito at Sep 26, 2019, 5:25:45 AM]
[Sep 26, 2019, 5:12:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@waleedfahmy
VeroniQ has created a blog tutorial "How to create a nice photo rendering" and a video tutorial "How to create nice photo renderings".
Ceciliabr has created a detailed tutorial explaining his techniques and tips for a photo-realistic rendering.
For the description of the Sunflow rendering parameters, you can consult this document.
EnkoNyito
[Sep 26, 2019, 5:22:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
waleedfahmy
Egypt
@waleedfahmy
Thank you :)
[Sep 26, 2019, 12:48:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
No, but that's not a biggie.
Regarding the transparency, that's not a biggie either, but it could be an option?
Is it really important to see the size of the image?
It's only when using Spiral that you're not able to visually imagine the size of the finished rendering.
Looking forward to that.
But please don't abandon Sunflow quite yet.
[Sep 26, 2019, 9:56:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
I think so because it is scaled to be visible in the photo panel regardless of its resolution.
I do not intend to abandon Sunflow but I prefer to leave the choice of the rendering engine to the end user as in this old plug-in by adding YafaRay. This will imply a change of the interface by favoring the display of advanced settings.
EnkoNyito
[Sep 28, 2019, 2:12:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bravo enko ! applause
[Sep 28, 2019, 8:49:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
PhotoVideoRendering-1.8 plug-in
- saving the image after stopping a rendering (simple photo panel)
- semi-transparent image background (simple photo panel)
- added a photo preview while rendering (video panel)
- added other shininess shader (rendering properties)
- management of Sunflow standard options
AdditionalSunflowOptions-1.2 plug-in
- added Sunflow standard options
Enko Nyito
EnkoNyito
[Oct 1, 2019, 4:20:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
This plugin is perfect!
I love the different rendering options and the new save function. Rendering parts of an image, saves a lot of rendering time when you want to correct something.
Now I just have to learn what all the new parameters are doing, and how to use them.
Excellent work!
Thank you!
[Nov 4, 2019, 10:37:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
