PhotoVideoRendering-1.7 plug-in - added an ambient lighting slider (simple photo panel) - fixed a bug in the management of curved lines (video panel) - fixed a bug in the management of speed values (video panel) - added other global illumination (rendering properties) - management of additional Sunflow options - compatibility with the standard version of SH3D and its derived version
SH3D-6.2_derived executable jar - added an independent ceiling light in each room - added Fake Ambient Term 2 global illumination - grouping the actions of a same plug-in in a menu - other minor enhancements
Enko Nyito
EnkoNyito
[Edit 1 times,
last edit by enkonyito at Jul 15, 2019, 4:53:07 AM]
Thank you for the new (version of the) plug-in and the JAR. I'm trying them out, but have some problems.
The JAR runs without problems under Windows 10 64-bits, but when I try to make a render I run into memory problems. The JAR runs in 32-bit mode and allows only 0.2 GB of memory, that's not enough to do any serious work. Can you increase the memory allowance, or offer a version that allows the standard installation?
@hansmex
You can run the JAR file with a script using java options like increasing the memory.
java -Xmx2g -jar path/to/SH3D-6.2_derived.jar
Maintaining a derived version requires a lot more work than a plug-ing because you have to create a new one with every standard Sweet Home 3D update. What I do not plan to do... I released the version derived from SH3D-6.2 to show the possibilities of the modifications made to the program.
@MichaelN
Is there any Help for the Rendering Plugin?
This tutorial explains how the plug-in works for rendering properties. With PVR-1.7, "default" global illumination is replaced by "Ambient Occlusion" and "path" by "Path Tracing".
And it's common, that it needs several hours for 1600x Pixel?
It depends on your scene (number of lights, activated ceiling lights, shininess of objects, enhancement of external brightness) and rendering settings (number of antialiasing, type of global illumination, type of sampler algorithm).
Not sure if it works on Windoof, but go to your SweetHome3D directory, open the lib folder, rename the SweetHome3D.jar to anything else, rename the JAR-file from Enko to SweetHome3D.jar and copy it to the lib folder in your SweetHome3D directory. Then start your SweetHome3D as usual...
Pascal
[Note: Updated download links to include video rendering and bug fixes in standard options.]
---------------------------------------- PVR-1.8_betaTest2.sh3p
(353864 bytes)
(Download count: 374940)
EnkoNyito
[Edit 1 times,
last edit by enkonyito at Aug 28, 2019, 8:56:23 PM]
Perfect!
After some testing, I have found that a buffer size of 48 is marginally faster than 64 and 32. Is it automatically detecting the number of threads available?
Quite oddly, it seems that choosing different bucket orders has an impact on the rendering time. This is rendered with column.
Hilbert : 39 s Spiral : 39 s Row : 38 s Column : 35 s Diagonal : 35 s Random: 48 s
I didn't try the reverse options – but I must admit I was somewhat curious about the reverse random...
I noticed no difference with the threads.lowPriority activated.
The project file is meant as an illustration of the rather hot inner core of the earth (intended for the education of my daughters), and I wanted it to spin, so I tried making a video. It seems the video will not render in Q4, but stops about half way.
I'm including the project file, in case anyone wants to give it a try ( 1280 x 536 )
@Ceciliabr
Yes, the number of threads by default is the number of available processors (CPU) that will be the maximum value because I noticed a bug by opening your file on my computer which has only 4 cores.
I think it depends on the scene. With yours where the subject is central and the background black, the order has an influence especially on the calculation of the remaining time.
The "reverse random" bucket order will be removed.
This is what I also found but I do not do any action in the plan or the 3D view during a rendering.
Version 1.7 of the plug-in uses only the default values of the new options. I will test with different video format because the lighting significantly increases the duration of the rendering.
