Total posts in this thread: 226
Posts: 226   Pages: 23   [ Previous Page | 14 15 16 17 18 19 20 21 22 23 | Next Page ]
Previous Thread This topic has been viewed 686057 times and has 225 replies Next Thread
YGYL
Found a bug, when the sky box texture is set, SUNFLOW engine rendering ray tracing will become completely black
[Oct 5, 2022, 4:59:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@varigonda
When you click on Stop, the Save button becomes available if rendering has stopped correctly and it is possible to save your image. If not, your rendering has terminated abnormally.
@YGYL
To use Path global illumination with a sky texture, sky lighting must be enabled.
EnkoNyito
[Oct 5, 2022, 6:49:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@Puybaret
It would be better to reuse the DLLs available in Sweet Home 3D in your plug-in, but then you'll get the error you reported. As removing these DLLs from your plug-in will prevent it to work with older versions of Sweet Home 3D, I think it's better to keep them with your plug-in for the moment.
Indeed, it is more practical to keep the YafarayRendering-1.4.5 plug-in dlls otherwise it would have been necessary to create a version derived from SweetHome3D-7.0.
A question that has nothing to do. How to modify the luminosity of the sky (color or texture) as it is already the case for the ground with Java3D (3D view)?
EnkoNyito
[Dec 31, 2022, 7:54:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
PhotoVideoRendering-2.5 plug-in
EnkoNyito
[Mar 31, 2023, 10:43:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Enko,
Thank you for this fantastic update.
To test, I made 3 renders of the same file (see below).
From left to right: Sunflow, Java, Yafaray.
I notice strange "light bars" in the Yafaray render.
https://www.mediafire.com/view/kh0sl930wgeyuwb/Klochenko_3_renders.PNG/file
Is there an explanation, or is it a bug? (original file )
[Apr 1, 2023, 6:58:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Vinci68
Hello hansmex
Indeed in yafaray I have the same rendering:
https://www.mediafire.com/view/ys0oq0iapc335d6/Klochenko_A-house2.png/file
Strange !
[Apr 1, 2023, 12:22:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
With the newest PVR 2.5, I've got this :
Why ?
FYI : my PC - Core i9, RAM = 32 Go, GC = RTX 2080
Version OpenJDK 11.0.18 - 64bit - 2,8 / 13,6 Go fournie par Azul Systems, Inc. Version Java 3D 1.6.2a - JOGL 2.4.0-rc-20221118 fournie
biggrin
[Apr 4, 2023, 9:39:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@hansmex, @Vinci68,
The "light bars" observed with the YafaRay rendering engine are due to the light panels created when the Add ceiling lights option is checked, so this is normal.
For information, the dlls used are those of the YafarayRendering-1.4.5 plug-in.
I just noticed the bug with SunFlow because these same light panels are no longer taken into account since compatibility with SH3D-7.0.
If this is not easily correctable and given that the option is not optimal according to the shape of the ceilings, the default behavior of SweetHome3D can be restored.
@bdfd,
This error message replaces the red cross of a default rendering. It appears when the memory allocated to SH3D is not sufficient to render an object which may have a certain complexity.
EnkoNyito
[Apr 5, 2023, 7:06:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TY.
Occasional problem that has not reappeared since!
To monitor...
wink
[Apr 7, 2023, 5:12:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
The Photo-video rendering plug-in is now available through the Plugin manager!
[Apr 11, 2023, 1:50:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
