dear team... I am not posting so much in this forum... I am really an amateour of SH3D, for my porpuses I reached a good level of satisfaction in rendering. I was excited to read all about thsse rendering new features..but I have a question... when rendering with the menu optio create photo with yafaray I obtain a bright result (don't know how to post a photo here) when using the new 2.1 plug in...all of a sudden it becomes all dark? where do I make mistake?
Why is the rendering so much slower when i use the Photo-Video Plugin insted the yafaray plugin?
The YafaRayRendering plug-in uses a standard configuration just like the SunFlow rendering engine in the 'Create photo' panel. The PhotoVideoRendering plug-in uses an advanced configuration to maximize the properties of rendering engines (SunFlow, YafaRay).
Can i disable the "advanced configuration" or can you give me an advise for some settings? It takes 4-10 times longer with the rendering plugin. I only need the "Multiple Photo Rendering" function.
@Magokelvin
This How to share images and files post pinned to the forum gallery will be helpful to you. Then post a screenshot of the Create photo / YafaRay panel with a finished rendering. Do the same with the Simple photo rendering (v2.1) panel and the properties panel of the selected rendering engine.
These images may help to better understand your problem.
@Baker0052
The standard or advanced configuration I'm talking about is done internally as for the management of the default rendering engine. Some parameters are accessible in the rendering properties. I have indicated here the antialiasing correspondence between SunFlow and YafaRay.
Depending on your hardware (number of processor cores, memory allocated to SH3D), I advise you to perform tests in order to find your customization of the parameters. The 3D scene also plays a lot on the rendering time (number of lighting, shininess of objects, detail of objects).
EnkoNyito
@Baker0052
I got dual Xeon Silver 4214 and started java with 48G ram. It still takes about 1 Hour per picture when i use many lights.
thanks for the hints:-) here we are ..bath 1 ( made via yafaray tool) lights are what I was planning to have in terms of lights...it took roughly 7 hours
here with the new tool. I did not finished for it still asking for 33hours to go.. for sure it looks more precise with the reflections - see the toilet paper in the glass - (though less crisp than yafarey one)
However you can see light is darker (I tried different paremeters combinatiosn but no improvements..)
@Magokelvin
What diffuse light are you talking about? If you are using the new automatic light sources, it is normal that they are switched off during the day and on at night.
EnkoNyito
THe question however remain why at the same conditions "old" yafaray plugin is much brighter while the new one makes images darker (much darker) at the same light and time conditions...
whatever is the lightsource though, it should be switched off in both cases which is not...in one case it is switched on somehow for If I remove those the imge is totally dark, with the new plug in the image is clearly much darker
HOw should I by your experience to obtain the same brightness of the image of the old one, but benefiting of the new plugin rendering performances? ...
If it is not the other types of light that are causing a darker rendering, it is difficult to answer without seeing the project.
EnkoNyito
