Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Photo-video rendering plug-in » » » » Post: Re: Photo-video rendering plug-in |
Print at Sep 14, 2026, 7:26:05 AM |
| Posted by Baker0052 at Jan 4, 2021, 6:30:54 PM |
Re: Photo-video rendering plug-in @Baker0052 Can i disable the "advanced configuration" or can you give me an advise for some settings? It takes 4-10 times longer with the rendering plugin. I only need the "Multiple Photo Rendering" function. The standard or advanced configuration I'm talking about is done internally as for the management of the default rendering engine. Some parameters are accessible in the rendering properties. I have indicated here the antialiasing correspondence between SunFlow and YafaRay. Depending on your hardware (number of processor cores, memory allocated to SH3D), I advise you to perform tests in order to find your customization of the parameters. The 3D scene also plays a lot on the rendering time (number of lighting, shininess of objects, detail of objects). I got dual Xeon Silver 4214 and started java with 48G ram. It still takes about 1 Hour per picture when i use many lights. |
Current timezone is GMT Sep 14, 2026, 7:26:05 AM |
