Total posts in this thread: 6
Previous Thread This topic has been viewed 5489 times and has 5 replies Next Thread
rdorsch
My roof hovers above the building
I modeled a building and found that my roof hovers over the building.
I used the slope ceiling guide to draw the roof
http://www.sweethome3d.com/slopingCeilingGuide.pdf
I omitted Steps 4 to 7 on Page 7
4 - While selected, click Tools → Copy as new furniture.
5 - Right-click → Paste to insert the newly made roof section.
6 - Delete the walls, but keep the copy.
I did not find a Tools->Copy entry, are these instructions outdated?
When I import the roof, it hovers about 20cm above the building.
My sweethome3d file is here
http://netcup.bokomoko.de/~rd/hover.sh3d
Any hints are very welcome.
Thanks
Rainer
[Mar 13, 2016, 5:39:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: My roof hovers above the building
Nice plan smile The level (DG) on which the roof is placed is too high (for the roof). Several ways of changing this. If you do not want to adjust the walls (and level heights) you can add a separate level for the roof (20 cm lower than the top floor) - and hide that level when you design the interior (ctrl-shift-h).
This is - btw - one case where a negative elevation really would be useful. Also, noticed the auto-ceilings in your loft are not correctly aligned, not always easy to fix with sloping walls. Once you have fixed the roof, you may want to forget the ceilings. Many threads regarding this issue - see for instance thread 6563.
[Mar 14, 2016, 11:35:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
josephmakia
Cameroon
Can Some One Help Me Locate the Feature to Add a Roof to my Drawing ? I don't seem to see Any Feature As Roof . Please Help
[Aug 12, 2016, 12:05:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi rdorsch
you need to move the roof down 1 level (cut and paste) then raise it to the required height
[Aug 13, 2016, 10:03:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi josephmakiaI
I do not think there are any roof sections in the library , they are generally made for each individual house.
In the forum there are several explanations on how to do this, including some roof sections you can get,okh, hansmek and arun explain much about this here
[Aug 13, 2016, 10:14:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
phpnukes
Roofs are classed as furniture. Just type roof and three should appear
[Oct 24, 2023, 1:31:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
