Total posts in this thread: 12
Previous Thread This topic has been viewed 9770 times and has 11 replies Next Thread
l4fr4gol4
Furniture librari editor and texture editor problem
I also have problem related to my sweet home first thread...When i click on jar executables of furniture editor and texture editor located in system drive C, they dont fork and open...when i copy files to partition d or e and f, when i double click they work.
[Oct 21, 2015, 8:19:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Furniture librari editor and texture editor problem
Very strange.
Please run cmd and try to launch the Jar executable with the following command:
java -jar C:\path\to\FurnitureLibraryEditor-1.18.jar
where you'll replace path\to by the real path to the Jar file (you can also drag and drop the FurnitureLibraryEditor-1.18.jar file in the cmd window to get its full path more quickly.
In case of error, the cmd window should display some information that will be helpful to understand your issue.
[Oct 24, 2015, 9:39:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Same here. I do not have Java installed but I do have the SH3D installer with Java.
Here's what I get from the command window.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Hawk>"X:\Software2\Graphics\Sweet Home 3D\FurnitureLibraryEditor-1.18.jar"
C:\Documents and Settings\Hawk>java -jar X:\Software2\Graphics\Sweet Home 3D\FurnitureLibraryEditor-1.18.jar 'java' is not recognized as an internal or external command, operable program or batch file.
Hawk
[Oct 25, 2015, 2:58:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
l4fr4gol4
I Executed jar file through cmd but nothing heppens...just like i click on executable...i see the sand clock and nothing. I also have to say, when i put this hdd (with this partition c and also have partition d )on another computer and i try to execute furniture library editor its the same...but when i execute in any other partition (partition d on same hdd or on another hdd)exept this partition , then jar file works.
So jar executables dont work when partition is active with drive letter c, and also when partition is not system when i plug hdd on another pc.
[Oct 26, 2015, 9:15:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
OK! Taking your suggestion, I copied the jar file to D drive and got the same thing.
C:\Documents and Settings\Hawk>java -jar D:\Modeling\Sweet Home 3D\lib\FurnitureLibraryEditor-1.18.jar
Hawk
[Edit 2 times, last edit by HawkDawg at Oct 26, 2015, 10:37:42 PM]
[Oct 26, 2015, 10:36:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg, you must install Java to run the Furniture Library Editor.
l4fr4gol4, I don't know what's going on in your case, but I'm sure that the Editor can be run from any drive.
[Oct 26, 2015, 11:11:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Ah! I thought you could run it with the Java that comes with the SH3D installer.
Thanks for clearing that up for me.
Hawk
[Oct 27, 2015, 12:29:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
This is where I got the idea that the Java that comes with the SH3D Installer would work for the Furniture Library Editor.
http://www.sweethome3d.com/support/forum/viewthread_thread,1550
The program is available as a 4.6 MB JAR executable file and requires you installed Java on your machine (or reuse the Java version embedded with Sweet Home 3D installer ).
Hawk
[Oct 28, 2015, 12:17:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry, if you installed Sweet Home 3D 5.1 in the default folder, you can reuse the JRE bundled with it using the following command:
C:\Program Files\Sweet Home 3D\jre1.8.0_60\bin\javaw.exe -jar \path\to\ FurnitureLibraryEditor-1.18.jar
[Oct 28, 2015, 2:01:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
I tried that and it looks like the space after Sweet causes the command window to not accept the address of the installation of SH3D.
C:\Documents and Settings\Hawk>"D:\Modeling\Sweet Home 3D\jre1.8.0_60\bin\javaw.exe"
C:\Documents and Settings\Hawk>D:\Modeling\Sweet Home 3D\jre1.8.0_60\bin\javaw.exe -jar X:\Software2\Graphics\Sweet Home 3D\FurnitureLibraryEditor-1.18.jar
'D:\Modeling\Sweet' is not recognized as an internal or external command, operable program or batch file.
Hawk
[Edit 1 times, last edit by HawkDawg at Oct 28, 2015, 4:28:19 PM]
[Oct 28, 2015, 4:27:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
