Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Furniture librari editor and texture editor problem |
| Print at Sep 29, 2026, 5:02:38 PM |
| Posted by l4fr4gol4 at Oct 21, 2015, 8:19:32 PM |
Furniture librari editor and texture editor problem I also have problem related to my sweet home first thread...When i click on jar executables of furniture editor and texture editor located in system drive C, they dont fork and open...when i copy files to partition d or e and f, when i double click they work. |
| Posted by Puybaret at Oct 24, 2015, 9:39:11 PM |
Re: Furniture librari editor and texture editor problem Very strange. Please run cmd and try to launch the Jar executable with the following command: java -jar C:\path\to\FurnitureLibraryEditor-1.18.jarIn case of error, the cmd window should display some information that will be helpful to understand your issue. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by HawkDawg at Oct 25, 2015, 2:58:26 AM |
Re: Furniture librari editor and texture editor problem Same here. I do not have Java installed but I do have the SH3D installer with Java. Here's what I get from the command window. Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\Hawk>"X:\Software2\Graphics\Sweet Home 3D\FurnitureLibraryEditor-1.18.jar" C:\Documents and Settings\Hawk>java -jar X:\Software2\Graphics\Sweet Home 3D\FurnitureLibraryEditor-1.18.jar 'java' is not recognized as an internal or external command, operable program or batch file. ---------------------------------------- Hawk |
| Posted by l4fr4gol4 at Oct 26, 2015, 9:15:54 PM |
Re: Furniture librari editor and texture editor problem I Executed jar file through cmd but nothing heppens...just like i click on executable...i see the sand clock and nothing. I also have to say, when i put this hdd (with this partition c and also have partition d )on another computer and i try to execute furniture library editor its the same...but when i execute in any other partition (partition d on same hdd or on another hdd)exept this partition , then jar file works. So jar executables dont work when partition is active with drive letter c, and also when partition is not system when i plug hdd on another pc. |
| Posted by HawkDawg at Oct 26, 2015, 10:36:19 PM |
Re: Furniture librari editor and texture editor problem OK! Taking your suggestion, I copied the jar file to D drive and got the same thing. Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\Hawk>java -jar D:\Modeling\Sweet Home 3D\lib\FurnitureLibraryEditor-1.18.jar 'java' is not recognized as an internal or external command, operable program or batch file. ---------------------------------------- Hawk |
| Posted by Puybaret at Oct 26, 2015, 11:11:54 PM |
Re: Furniture librari editor and texture editor problem HawkDawg, you must install Java to run the Furniture Library Editor. l4fr4gol4, I don't know what's going on in your case, but I'm sure that the Editor can be run from any drive. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by HawkDawg at Oct 27, 2015, 12:29:16 AM |
Re: Furniture librari editor and texture editor problem HawkDawg, you must install Java to run the Furniture Library Editor. Ah! I thought you could run it with the Java that comes with the SH3D installer. Thanks for clearing that up for me. ---------------------------------------- Hawk |
| Posted by HawkDawg at Oct 28, 2015, 12:17:26 PM |
Re: Furniture librari editor and texture editor problem This is where I got the idea that the Java that comes with the SH3D Installer would work for the Furniture Library Editor. http://www.sweethome3d.com/support/forum/viewthread_thread,1550 The program is available as a 4.6 MB JAR executable file and requires you installed Java on your machine (or reuse the Java version embedded with Sweet Home 3D installer ). ---------------------------------------- Hawk |
| Posted by Puybaret at Oct 28, 2015, 2:01:43 PM |
Re: Furniture librari editor and texture editor problem Sorry, if you installed Sweet Home 3D 5.1 in the default folder, you can reuse the JRE bundled with it using the following command: C:\Program Files\Sweet Home 3D\jre1.8.0_60\bin\javaw.exe -jar \path\to\ FurnitureLibraryEditor-1.18.jar ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by HawkDawg at Oct 28, 2015, 4:27:40 PM |
Re: Furniture librari editor and texture editor problem I tried that and it looks like the space after Sweet causes the command window to not accept the address of the installation of SH3D. Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\Hawk>"X:\Software2\Graphics\Sweet Home 3D\FurnitureLibraryEditor-1.18.jar" C:\Documents and Settings\Hawk>"D:\Modeling\Sweet Home 3D\jre1.8.0_60\bin\javaw.exe" C:\Documents and Settings\Hawk>D:\Modeling\Sweet Home 3D\jre1.8.0_60\bin\javaw.exe -jar X:\Software2\Graphics\Sweet Home 3D\FurnitureLibraryEditor-1.18.jar 'D:\Modeling\Sweet' is not recognized as an internal or external command, operable program or batch file. ---------------------------------------- Hawk |
Current timezone is GMT Sep 29, 2026, 5:02:38 PM |
