Total posts in this thread: 42
Posts: 42   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Previous Thread This topic has been viewed 110709 times and has 41 replies Next Thread
enkonyito
Re: Other rendering quality levels
By testing with SH3D-4.6, the problem occurred.
Version 1.1 of the plug-in is compatible with Java 6.
EnkoNyito
[Sep 17, 2015, 11:47:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks, it works this time smile
Not with Java Web Start version, but you can't do anything against that because it's due to security reasons in that environment.
[Sep 18, 2015, 8:46:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Vkbear0
Thank you for this reply! This helps me a lot!
-The Hobbyist
[Sep 19, 2015, 8:13:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Interesting plug-in and like the concept. While most of the menu items are understandable, some are not obvious (causticsPhotons???).
Photo (and video) rendering is always a trade-off between time and quality, and I wonder how the different values influence on performance. Trying and failing takes a bit too long. Maybe a little introduction/description/guide could be useful? Or just a little more explanatory text in the menu?
[Oct 2, 2015, 10:05:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
The plug-in in its current state is made for users who used a SweetHome3D.l4j.ini file, a Linux launch script or Jar command lines to change the photo renderer properties.
In this thread , Emmanuel Puybaret gives some explanation about those properties.
And you can find information on caustics here .
Here are the definitions of the quality parameters given in the PhotoRenderer.properties file:
* Minimum and maximum antialiasing used to compute image
* Global illumination algorithm: "default" or "path"
- "default" uses ambient occlusion during day hours in virtual visit mode
- "path" takes much longer to compute but gives more realistic view at day hours
* Maximum bounces done by light rays when global illumination "path" is used
- Increasing this value greatly slows down rendering process
* Caustics photons count, with 0 producing no caustics
- If different from 0, should be higher than 1000000 to obtain some visible effect
* Shader used to render shiny materials: "default", "glossy" or "silk"
- "default" uses silk shader at high quality level and in virtual view mode, glossy otherwise
* Focus distance in cm when depth of field is used
* Lens radius when depth of field is used
- A bigger value produces a narrower depth of field
EnkoNyito
[Oct 4, 2015, 9:20:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks, now I am confused at a higher level. smile Looking forward to trying. ok
[Oct 5, 2015, 9:23:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Version 1.2 of the plug-in incorporates some additional information.
EnkoNyito
[Nov 14, 2015, 3:20:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Version 1.3 of the plug-in incorporates 2 new rendering properties (filter and samplerAlgorithm) from SH3D-5.2 .
Attachment configureSunflowRenderingEngine.pdf (227128 bytes) (Download count: 3221) (Configure the SunFlow rendering engine with Sweet Home 3D version 4.0 and higher.)
EnkoNyito
[Edit 1 times, last edit by enkonyito at Jan 15, 2016, 8:30:17 PM]
[Jan 13, 2016, 2:20:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mazoola
FYI, for anyone looking for detailed information on the SunFlow rendering engine, a PDF copy of the old SunFlow Wiki can be found here.
[Jan 13, 2016, 8:47:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
A couple of interesting examples of use in thread 6462. ok
[Jan 26, 2016, 8:15:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
