Re: Crash on clicking preferences
Ok, then what did you mean by "it doesn't work"? I also wonder if the -D... option should rather be placed before -jar option. Can you try?
Hi, same problem (crash on preferences) on Linux Debian (BunsenLab). Sorry but I did not understand how did you solved, I installed the Debian package and then I tried the version on SourgeForge. The fact is that Java is out of my knowledge and probably is just me that do not understand what you are talkking about.
goetz, the JNLP file you referenced won't solve wood's problem. It should rather be http://www.sweethome3d.com/SweetHome3D-NoOffscreen.jnlp
Thanks for replay. I am not using Sweet Home 3D with Java Web Start (do not have Java 6 installed, should I?). So I guess goetz answer did not fit my problem. And the file indicated by Puybaret is a .jnlp, so (for what I understood) is suppose to be used by a Java Web Starter (same story I guess).
Puybaret, you are right!
wood, just add the checkOffScreenSupport option when invoking sweethome3d. Your path may defer. dpkg -L sweethome3d will show you where the sweethome3d.jar file is. It maybe:
Canada
Had this problem with version 5.1 on Ubuntu 14.04. Used the suggested java fix line from the FAQ. Then I could change preferences. A side effect was that I could not longer delete walls. Removed the java line and then I could delete a wall again.
