Bad picture quality on lv3
Hello. I make room in SH3D. A take a picture and chose lv3. On lv3 always is bad image quality (noise). On lv1 and lv2 and lv4 (creates 20min...) it`s all OK. Ultrabook HP, i5-4200U, HD4400, 4GB RAM, Win 8.1 Pro 64bit.
Re: Bad picture quality on lv3
A better quality would make it much slower to compute. If ever, you want to improve quality settings of level 3, you can compute a larger a image and reduce its size with an image tool. You can also set the properties com.eteks.sweethome3d.j3d.PhotoRenderer.lowQuality.antiAliasing.min to 1 and com.eteks.sweethome3d.j3d.PhotoRenderer.lowQuality.antiAliasing.max to 2, as suggested here.
hy puybaret sorry but i don't understand where i can change the properties for high resolution, i see your posted link but i don't know what have i do, i have to create a file ini? and if yes, where i have to put it?
Did you try to change the width and height in pixels to a much higher value? This is the easiest way to remove noise, even if not the most efficient (in terms of required computer power).
