Total posts in this thread: 4
Previous Thread This topic has been viewed 2464 times and has 3 replies Next Thread
hrk
4 walls ,
hi.
i'm new to this forum ,
1. i have 4 texture for 4 side of the wall. How do i achieve this?
2. how do i donate a small token to this cause ? good job on this. impressive.
thanks
[Nov 10, 2014, 12:19:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 4 walls ,
Welcome,
If you count the top and the bottom of a wall, you could even wonder how to set the 6 sides of a wall! wink
But I guess you want to change only the vertical parts. As Sweet Home 3D offers to change only the left, right and top sides, you'll have to create very thin walls that you put at each end of the main wall.
Thanks. smile
You can use the Donate button found at the bottom of each page, or go to the Donate page.
[Nov 10, 2014, 8:35:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 4 walls ,
Maybe I misunderstand, but you can
1. split walls and assign different textures to different wall elements,
2. use a picture editor and edit the textures before applying them, see thread 5438
[Nov 10, 2014, 9:15:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hrk
Re: 4 walls ,
thanks guys !
i got it. just do 4 walls,joint them and apply 4 diff textures.
i was meddling with rooms no wonder the issue .
cheers
[Nov 11, 2014, 2:17:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
