Total posts in this thread: 2
Previous Thread This topic has been viewed 5184 times and has 1 reply Next Thread
Gemma1985
Can I remove a section of wall?
I have sections of wall that I need to remove from my design- is this possible? The walls are rounded, so it becomes very complicated to enter individual sections, so would like to be able to enter the whole wall, then erase parts?
Thanks
Gemma
[Oct 14, 2014, 10:39:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can I remove a section of wall?
..enter the whole wall, then erase parts?
Not to my knowledge - unless you insert an invisible window/door (must be placed/resized without magnetism - ALT key - if wall is curved - see thread 5366 ). But it is probably easier to edit wall elements manually with wall properties (start- and endpoints + arc extent).
Maybe you could use your existing plan as background image (select walls in the 2D window, copy, paste into a graphics editor, save as png and import as background image). If you draw on top of the background image, maybe it is easier?
Just a thought, but hard to tell without knowing more about your design. ok
[Oct 15, 2014, 11:47:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
