Total posts in this thread: 35
Posts: 35   Pages: 4   [ Previous Page | 1 2 3 4 | Next Page ]
Previous Thread This topic has been viewed 70314 times and has 34 replies Next Thread
HawkDawg
Re: Tiny display in Win 8.1
When you write the text file you have to save it as .ini, not .txt.
Hawk
[Nov 3, 2015, 10:29:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hawk, I think csi_bern succeeded to make his SweetHome3D.l4j.ini file work, but this solution doesn't show icons at a larger size.
csi_bern, if you know a little about Java, please see this thread and the patch proposed here. It should help until Oracle proposes a solution.
[Nov 4, 2015, 7:34:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
csi_bern
Suisse
Hi there,
Yes, that's exactly my problem.
I know a bit about Java, but I don't want to broke everything by doing something wrong. Further, I don't have time today to try it.
Since I have my new computer, I've also a similar problem with Adobe CS6. I found a full working solution there:link .
I've try it quickly yesterday at home with Sweet Home 3D, but it doesn't work. It was probably my mistake as I've done the manifest for a EXE file and not a Java file. Will it work with the good extension?
Thanks again for this great software
[Nov 4, 2015, 7:55:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The new version 5.2 proposes a new solution for HiDPI screens. I would be very happy to hear what you think about it.
[Feb 20, 2016, 8:44:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
From the feedback of two users, it looks like that the HiDPI Java Web Start version works correctly, but if you use the installer of version 5.2, setting com.eteks.sweethome3d.resolutionScale value in SweetHome3D.l4j.ini file might not be enough and still give incorrect results. If it's the case, you might have to reset the fonts size too, adding for example the 4 last lines of the following example in SweetHome3D.l4j.ini file:
-Dcom.eteks.sweethome3d.resolutionScale=2.5
-Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel
-Dswing.plaf.metal.controlFont=Dialog-11
-Dswing.plaf.metal.userFont=SansSerif-11
-Dswing.plaf.metal.systemFont=SansSerif-11
[Mar 8, 2016, 5:38:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
adlerhn
Europe
That works beautifully! I had set -Dcom.eteks.sweethome3d.resolutionScale=2, but some fonts were huge. I have now set the other parameters as suggested (keeping resolutionScale=2 though), and everything looks great.
[Jul 7, 2016, 1:22:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hds
België
Is there a solution for the online version? I have a 4K lapop screen...
[Jul 11, 2016, 4:41:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mtm216
Just to say that on Windows 10 on a Surface book I had the same issue, but this .ini file fix worked perfectly - Thanks
[Sep 11, 2016, 12:38:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gavinx
I am running a Lenovo Yoga and am having the problems mentioned above.
After applying the SweetHome3D.l4j.ini fix I got some relief. Everything displays correctly except for the list of furniture items used in the plan - which is displayed as a list in the lower left panel of the screen.
This list is scrunched up.
Is there a fix for this?
Thanks
[Dec 10, 2016, 1:40:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi.
I made this change to sh3d and must say the text size is much better for me, but, if i open - close - reopen a separate function, eg, photo or create shape, each time i open it the text size enlarges until it becomes unusuable, any idea why this would be.
Thanks
[Jan 8, 2017, 5:23:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
