Total posts in this thread: 35
Posts: 35   Pages: 4   [ Previous Page | 1 2 3 4 | Next Page ]
Previous Thread This topic has been viewed 70314 times and has 34 replies Next Thread
mliberatore
Re: Tiny display in Win 8.1
Thank you all for trying to help. None of the above helped. After installing version 5 today, at least the overlapping issue is resolved. The application is now usable on low resolution settings or a big screen. It appears, as I suspected, to have been related to the version of Java. The former version was very old. I have also upgraded to Windows 10. The display is still very small on my Surface Pro 3, and there is no preference in the application to set the font size of the app itself. That's really an oversight and I'll submit a feature request. Thank you all again!
[Jul 30, 2015, 2:37:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mliberatore
Actually, I retried Puybaret's fix above and it works now! It didn't make any difference at all before, but I am now able to set the text size to 30 and it is perfect! Thank you so much!
[Jul 30, 2015, 2:49:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
miekemook
I am having the same problem with Windows 10.
Made the text file as suggested by Puybaret but I cannot find the ini file in the C:\programfiles\sweethome 3D file.
Any other suggestion?
[Aug 6, 2015, 8:50:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The ini file doesn't exist. It's up to you to create it if you need one.
[Aug 6, 2015, 11:52:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
miekemook
I use Windows 10 and have exact the same problem. I made the text file but cannot find the ini file as is described?
What else can be done or how can the ini file be missing?
[Aug 7, 2015, 4:59:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
miekemook
I did copy and paste the lines of code in a note-pad file.
Saved the file as an ini file since I copied and pasted the name you gave in the text.
Copied the ini file into c:/programfiles/sweethome 3D and than restarted the program.
unfortunately still the same result: the fonts are to small and the text is overlaying.
[Aug 7, 2015, 5:12:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
miekemook
I installed the program on a windows 7 laptop and everything is working fine.
Seems to be a windows 10 problem.
[Aug 7, 2015, 5:29:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mliberatore
You create the file, name it correctly, paying particular attention to the file name extension, and save it to your desktop. Close the file then copy it to the folder. If you don't know where you saved the file open your text editor and look for the file in recent documents then do a "save as". Pay attention to where you're placing the file.
[Aug 7, 2015, 11:32:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
musaji
Just downloaded the app to create a floor plan for the house I want to build. Came across the font size issue on my windows 10 laptop (has 2k resolution). Thanks for the fix using the .ini file. I used font size 30.
When you save the file in notepad, make sure to name it using double quotes. It will make sure to preserve the .ini extension, otherwise, notepad will add .txt extension to you filename.
Hope it helps & thanks for the fix.
[Oct 8, 2015, 2:13:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
csi_bern
Suisse
Hi, thanks to Puybaret, the patch is working ... for the text.
Do you have an other for the icones?
Merci (bon programme au fait)
[Nov 3, 2015, 9:20:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
