Previous Thread This topic has been viewed 2768 times and has 9 replies Next Thread
Guyrws
GB
Rooms and Ceilings
Hello All,
Just started with SH3D and doing OK but can someone clear this up for me please?
To have a ceiling do you have to form a room first? i.e. how do I put a ceiling on 4 walls.
Cheers Guy.
[Sep 25, 2014, 9:17:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Rooms and Ceilings
Yes, you have to make a room first.
If you don't want a floor, just un-check that box.
[Sep 25, 2014, 11:35:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Guyrws
GB
Hello,
Thank you for your prompt reply.
Would it be ok to insert a room within what I've already created? Please see GDocs link.
https://drive.google.com/file/d/0BznwZlbnsGeMcmY3QVFaa042Qjg/edit?usp=sharing
Originally, I asked the question because, as you can see from the images below, for a newbie, I'm trying to create something rather advanced. Have you any advice with this please? I've read the relevant PDF tutorial for sloping roofs and ceilings, dormers.
https://drive.google.com/file/d/0BznwZlbnsGeMYi00SUR3SWdVaWM/edit?usp=sharing
Cheers, Guy.
[Sep 26, 2014, 10:18:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
For the ceilings alone - if I understand you correctly - you can create two rooms with the help of minimal wall (sent you a cheat file). However, when I look at your pictures I do not understand how you intend to finish the construction, you want sloped windows, bay windows, or?
[Sep 26, 2014, 11:17:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Guyrws
GB
This is what I'm trying to replicate:
https://drive.google.com/file/d/0BznwZlbnsGeMUGlLcnhmdlV4Q2M/edit?usp=sharing
Bay windows first. The sloping ceiling may be a bridge too far!!
[Sep 26, 2014, 11:55:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hard to tell without knowing the outside - if the outer walls are vertical, I would go with straight walls and add triangles for the support structure.
If wall/roof indents - that the windows protrude - it will require some measuring, exporting/importing/turning of .obj files to get it right.
As for the sloping ceiling, that may actually not be too hard if you draw a wall like this _/\_, export it to .obj, import and rotate it - and then stick the ceiling/roof on a separate level.
[Sep 26, 2014, 2:31:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Guyrws
GB
I'm still having trouble getting the ceiling to drop with the slopped walls. I've solved a ceiling problem in another thread and made sure they all level and no rouge walls.
Here are some screenshots to demonstrate where I'm at:
https://drive.google.com/folderview?id=0BznwZ...pNY1pEYTA&usp=sharing
I was wondering if the joints between walls would cause a problem? I've included a screenshot from your cheat sheet and my construction showing diagonal joints in yours and right angles in mine. I've tried joining the wall but all sort of weird things happen, I've included a shot of this as well.
[Sep 26, 2014, 4:35:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Don't know whether the joints influences ceiling calculation. If you use the AdvancedEdit plugin to connect walls, make sure the direction of the walls are the same and that you select the walls in proper order. There are some oddities in the AdvancedEdit, but on second attempt it usually works - and could not live without...
Judging by your pictures of the bay windows (?), I am not so sure I would use sloped ceilings calculated automatically. It is probably easier to rely on import/export/flip of the elements you want.
[Sep 26, 2014, 7:51:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The examples in thread 5364 may help explain what I mean. Note that the roof (and ceiling) elements are put on a separate level.
[Sep 29, 2014, 11:59:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
josephrohdes221
very nice explanation by members of this forum, I do got some information here how to to do. Thanks
[Sep 30, 2014, 9:17:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
