Total posts in this thread: 4
Previous Thread This topic has been viewed 6105 times and has 3 replies Next Thread
PeterWeber
rose I found the rooms to be much smaller in 3D view than they are.
Whenever I used a floor plan of a flat in sh3d as a background and later on walked through it using the 3D view the areas were always smaller than they are.
Why is that and what to change?
[Aug 30, 2014, 1:25:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: I found the rooms to be much smaller in 3D view than they are.
Not sure what you mean. Were the dimensions in the 2D plan correct? If not, you may have to re-scale your plan. As for the walk-through (virtual visitor), could it be a question of perspective? Does it still look wrong if you adjust the field of view? ok
[Aug 31, 2014, 5:34:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PeterWeber
What fov should I use to have a real life perception?
[Sep 2, 2014, 6:46:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Well, that depends on your personal perception of your own field of vision. I tend to find that the default is a bit narrow minded for my taste - and increase the FOV by 10-30%. But a again, it is up to you, but you should see a difference if you try to increase it. See if it works smile - and good luck. ok
[Sep 2, 2014, 11:51:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
