Cameroon
Wall Creation
Is there a possibility of creating a wall which is not completely covered that is the wall contains holes. I guess such wall is used to ease ventilation. I will love to use that in my house but can't see it in sh3d or its models. Thanks
Re: Wall Creation
From this page you can import models like box, triangle, cylindrrs, etc. During importation, make sure to check Doors/windows. If necessary rotate them into the correct position. Now you can insert these objects in a wall, and they will give a hole of the desired shape.
Cameroon
Re: Wall Creation
Thanks Hans, I tried but the cylinder is not open at both ends so eventually I cannot obtain holes. can somebody help me with an object cylinder open at both ends
Re: Wall Creation
- Search the Sketchup Warehouse. - Search the forum for invisible boxes, cylinders, etc or how you can make any object invisible by manipulating the MTL file.
---------------------------------------- cylinder invisible.zip
(1902 bytes)
(Download count: 194)
[Edit 2 times,
last edit by hansmex at Aug 28, 2014, 12:14:13 PM]
