Previous Thread This topic has been viewed 7025 times and has 12 replies Next Thread
TNTDAVID
To create an opening in a work-top ?
Hello, smile
I go proposed 25 models of work-top without openings for kitchen sinks.
Is it possible to create these openings afterward ?
Or is it necessary that I to create 25 plans of work in more with openings ?
Thank you for your help.
Cordially
David Barros
On www.composant-dynamique.com create the kitchen of your dreams.
[Aug 15, 2014, 4:05:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: To create an opening in a work-top ?
David,
In SH3D you can't add holes in worktops.
So, you would have to create separate worktops with holes in a 3D modelling program.
To make live a bit easier, maybe you could make your worktops modular, creating sections of worktop for different sizes of sinks and stoves.
[Aug 15, 2014, 6:44:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TNTDAVID
That you want to say by modular work-top ?
[Aug 15, 2014, 7:01:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Examples:
End piece straight and rounded
Middle piece, one size can be stretched to any size
Sink piece, for sinks in various sizes
Corner piece
You then use several pieces (modules) to make your worktop.
[Edit 1 times, last edit by hansmex at Aug 15, 2014, 11:21:24 PM]
[Aug 15, 2014, 8:32:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TNTDAVID
What do you think of this solution ?
[Aug 15, 2014, 10:22:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I think that is what I meant... :-)
[Aug 15, 2014, 11:20:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Just re-installing a worktop with sink today (broken washing machine sad). I will use a round Ø 45 cm sink, mounted in the very corner of the work-top.
So I agree, the solution is good, but suspect
1) many users would find it difficult to combine the pieces of the model (?).
2) and it would not fit special needs (like mine).
I guess that is why the 3D models: sink are all ready assembled. And that works if you can be bothered to put together at least the most common combinations.
[Aug 16, 2014, 11:52:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TNTDAVID
I understands but I wish to propose 25 models of work-top with 10 kitchen sinks in choices.
Who makes 25 x 10 = 250 possible combinations.
Maybe that I too much want to make it ?
To facilitate the use of my products, I am going to make a video of demonstration or I realize a kitchen from A to Z.
Thank you for your recommendations.
[Aug 16, 2014, 3:52:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TNTDAVID
The image below, presents a kitchen sink in 2D and an other one in 3D:
What solution to choose knowing that the 2D kitchen sink is much easier to use?
Thank you for expressing your opinion.
[Aug 16, 2014, 6:24:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
I vote for 3D but you can try to make it show bather in 2D (top view).
[Aug 16, 2014, 6:50:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
