Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: To create an opening in a work-top ? |
| Print at Sep 19, 2026, 2:08:57 PM |
| Posted by TNTDAVID at Aug 15, 2014, 4:05:19 PM |
To create an opening in a work-top ? Hello, I go proposed 25 models of work-top without openings for kitchen sinks. Is it possible to create these openings afterward ? Or is it necessary that I to create 25 plans of work in more with openings ? Thank you for your help. Cordially David Barros ---------------------------------------- On www.composant-dynamique.com create the kitchen of your dreams. |
| Posted by hansmex at Aug 15, 2014, 6:44:59 PM |
Re: To create an opening in a work-top ? David, In SH3D you can't add holes in worktops. So, you would have to create separate worktops with holes in a 3D modelling program. To make live a bit easier, maybe you could make your worktops modular, creating sections of worktop for different sizes of sinks and stoves. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by TNTDAVID at Aug 15, 2014, 7:01:25 PM |
Re: To create an opening in a work-top ? That you want to say by modular work-top ? ---------------------------------------- On www.composant-dynamique.com create the kitchen of your dreams. |
| Posted by hansmex at Aug 15, 2014, 8:32:38 PM |
Re: To create an opening in a work-top ? Examples: End piece straight and rounded Middle piece, one size can be stretched to any size Sink piece, for sinks in various sizes Corner piece You then use several pieces (modules) to make your worktop. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by TNTDAVID at Aug 15, 2014, 10:22:18 PM |
Re: To create an opening in a work-top ? What do you think of this solution ? ---------------------------------------- On www.composant-dynamique.com create the kitchen of your dreams. |
| Posted by hansmex at Aug 15, 2014, 11:20:00 PM |
Re: To create an opening in a work-top ? I think that is what I meant... :-) ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by okh at Aug 16, 2014, 11:52:58 AM |
Re: To create an opening in a work-top ? Just re-installing a worktop with sink today (broken washing machine ). I will use a round Ø 45 cm sink, mounted in the very corner of the work-top. So I agree, the solution is good, but suspect 1) many users would find it difficult to combine the pieces of the model (?). 2) and it would not fit special needs (like mine). I guess that is why the 3D models: sink are all ready assembled. And that works if you can be bothered to put together at least the most common combinations. ok |
| Posted by TNTDAVID at Aug 16, 2014, 3:52:56 PM |
Re: To create an opening in a work-top ? I understands but I wish to propose 25 models of work-top with 10 kitchen sinks in choices. Who makes 25 x 10 = 250 possible combinations. Maybe that I too much want to make it ? To facilitate the use of my products, I am going to make a video of demonstration or I realize a kitchen from A to Z. Thank you for your recommendations. ---------------------------------------- On www.composant-dynamique.com create the kitchen of your dreams. |
| Posted by TNTDAVID at Aug 16, 2014, 6:24:16 PM |
Re: To create an opening in a work-top ? The image below, presents a kitchen sink in 2D and an other one in 3D: What solution to choose knowing that the 2D kitchen sink is much easier to use? Thank you for expressing your opinion. ---------------------------------------- On www.composant-dynamique.com create the kitchen of your dreams. |
| Posted by dorin at Aug 16, 2014, 6:50:05 PM |
Re: To create an opening in a work-top ? I vote for 3D but you can try to make it show bather in 2D (top view). ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 19, 2026, 2:08:57 PM |
