Previous Thread This topic has been viewed 7757 times and has 9 replies Next Thread
seabird
Problems creating a light
Hi everybody,
recently switched to SH3D and am exploring the options and impressed with options and configuration. The one thing I am having problems with is creating a functional lamp/light.
I created my home/kitchen light
The problem is when I insert light sources I do not get the same "lightbulb". That distinct light inside glas spot is missing (hard to explain I guess)
Also, I create the lamp itself in Blender, and edited the material after export for transparency. But is there a way to make the object a Light? Should I do this in Blender?
[Jul 22, 2014, 12:54:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Problems creating a light
Nice lamp. Yes, you can add light sources to your models, but .obj format does not support lights (unless I missed something). However, if you use the Furniture Library Editor and import your model, you can manually add properties for sh3d models - including lights.
There are threads on this if you search and more info in the Source Forge documentation. I hope you will share your model. Good luck.
PS: I never find posts when I need them, so I added a little memo in the SVG manual on page 9 and 10 More editing: PluginFurnitureCatalog.properties.
[Jul 22, 2014, 12:18:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
seabird
cool, must have overlooked that in the repositories. Still needs a manual edit, but that's ok. Any handy tools to calculate the X,Y,Z, coordinates?
[Jul 22, 2014, 4:55:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
seabird
And for now I edited the material with D 0.50000 for a glas (see through) look. Or are there better ways for that?
[Jul 22, 2014, 5:26:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
D 0.5 sounds about right for a glazed bulb, but you can play with textures (semi transparent) and light colour too...
I find it easier to import the model to SH3D and re-export after having set the correct dimensions (this depends very much on the model software used). With rotation and dimensions present, I guesstimate the x, y, z co-ordinates for the light. Obviously, if you have the correct (absolutish) values in Blender, you can also use Blender to measure exactly.
I forgot to mention (in the SVG guide) that you can add several light sources to one object. More about that in the repositories, as you appear to be more than able to figure it out on your own smile - good luck, and it would be fun to see the result.
[Jul 22, 2014, 9:49:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
seabird
Yes, I figured it out mostly. Once the dimension is set (120cm) the coordinates are centimeter based. I added several lights and played with the MTL file.
name#2=Lamp onderdelen
category#2=Lights
icon#2=/Lamp onderdelen.png
model#2=/Lamp onderdelen/lamp%20onderdelen.obj
multiPartModel#2=true
width#2=120
depth#2=10.9091
height#2=562.14746
movable#2=true
doorOrWindow#2=false
lightSourceX#2=5 32.5 60 87.5 115
lightSourceY#2=5.5 5.5 5.5 5.5 5.5
lightSourceZ#2=3 3 3 3 3
lightSourceColor#2=#ffffff #ffffff #ffffff #ffffff #ffffff lightSourceDiameter#2=1 1 1 1 1
elevation#2=140
creator#2=Jacco
MTL:
# 3D model lamp onderdelen.obj
newmtl Brushed_metal
illum 2
Ka 0.0 0.0 0.0
Kd 0.168542 0.166863 0.166863
Ks 1.680151 1.680151 1.680151
Ns 128.0 Ni 1.0
newmtl Mat_Glas
Ka 1.0000 1.0000 1.0000
Kd 1.0000 1.0000 1.0000
Ks 1.0000 1.0000 1.0000
Tf 1.0000 1.0000 1.0000
Ns 200 Ni 1.2000
illum 7
d 0.94
newmtl Helder_glas
Ka 0.0000 0.0000 0.0000
Kd 0.0000 0.0000 0.0000
Ks 0.9000 0.9000 0.9000
Ns 200 Ni 1.2000
illum 6
d 0.3
After I manually changed the glass color to almost white in sh3d.
result so far (light is at 3% and a ambient light behind me to light the metal)
(still not the matt glass I want on top and still missing the "light source/bulb")
The light also needs to become "smoother".
[Jul 22, 2014, 10:10:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Looks like you're doing very well. Doesn't #ffffff render too white? ok
[Jul 23, 2014, 9:33:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
seabird
Thank you.
Most of it is moddeling in Blender too be honest (glad it is a easy shaped light).
Glass material seems to be a problem in sh3d.
to do:
-Make the top frosted
-Have a lightbulb that lights up
-Create a smoother render (more detailed boxes in blender?)
[Jul 23, 2014, 11:26:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
seabird
Ok, the frosting needs more fine tuning (help is appreciated), but the better models from blender did help.
newmtl Mat_Glas
Ns 40
Ni 0.4000
illum 9
d 0.90
The main thing missing now is a lightbulb (not so much the shape but the effect of the light origin. Any tips?
[Jul 23, 2014, 8:23:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you try making a sphere (bulb) with white-ish, semi-transparent texture (png with alpha channel / transparency, in stead of or in addition to transparency in the .mtl file)? ok
[Jul 26, 2014, 8:07:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
