Total posts in this thread: 6
Previous Thread This topic has been viewed 7752 times and has 5 replies Next Thread
Josso61
confused Is it possible to view 2D plan elevations or save the 2D plan as a DWG file?
Hi everyone in Sweet Home 3D land!
First post... i have to say i love this software, it's easy and quick to use and looks great!
I desperately need to know if it's possible to view the 2D plan in elevations? also, is it possible to save the 2D plan as a DWG file http://www.sweethome3d.com/support/mvnplugin/...ages/emotion/confused.gif
Thanks
[Jun 12, 2014, 9:28:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sree.arun.kr
INDIA
Re: Is it possible to view 2D plan elevations or save the 2D plan as a DWG file?
Method 1. Goto File->Print to pdf. Save it.Now you can use this pdf file (or open the 2nd page of the pdf file in Adobe Photoshop and save it into .jpg)
Method 2. Plan->Export to SVG format. Save it. Then Open the file with any other svg format supporting (Vector graphics)application like Inkscape or Adobe Illustrator. Then export it into bitmap(.bmp) or JPEG(.jpg) format.
Now send it to your friend. hugs cool
And here is the link how to post in SH3D forums.
[Jun 12, 2014, 11:52:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Josso61
Thanks again ARUN!
Is it possible to view the 2D plan in elevations, ie Front, back and sides?
confused confused confused confused
[Jun 13, 2014, 10:52:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sree.arun.kr
INDIA
Sorry, crying
Currently its not possible. 2D Window can produce only Top view(/Plan). d oh.
If you draw the plan completely. Then you can see the front and other sides in 3D window.
Check the official video tutorial . shhh
[Jun 13, 2014, 11:07:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
eriks
Finland
I use SH3D to make preliminary plans, but my architect can't use the sh3d fileformat. He requires my scetches as dwg-files. PDF flattens everything and is not sufficient.
If there is no possibility to export floorplans as dwg directly from SH3D, is there an external file converter that does the job?
[Sep 23, 2014, 6:22:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
With the menu 3D view > Export to OBJ format, you can export your home and keep the 3D part. Then, you or he will have to find a way to import this file or convert it to DWG.
[Sep 24, 2014, 11:40:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
