Previous Thread This topic has been viewed 6717 times and has 2 replies Next Thread
hfrmobile
Lower Austria
Copy&Paste between files
I am in the situation where I editing two .sh3d files. Sometimes I need to copy some furniture from one file to the other (so that I not have to adjust size, position, color etc. manually), but this seems not to be supported for the moment?
[Feb 16, 2014, 9:32:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Copy&Paste between files
Copy / paste between files should work, at least it works perfectly for me under Win 8.1, Java 1.6.0_45 / 64 bit. So if it doesn't work for you, it might help eTeks if you supply info about your environment.
[Feb 16, 2014, 10:39:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hfrmobile
Lower Austria
Thank you for your response!
Tried it on another machine and it worked. Sometimes the Paste menu item is grayed even the clipboard contains valid data. In that case just click somewhere on the plan and the menu item will be enabled.
One minor issue which would be worth an improvement: When pasting the object that it is not pasted into the current location/room. So you have to scroll a bit. But even this is better than not having the Copy&Paste between files :)
[Feb 17, 2014, 10:15:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
