Change level of a surface
i cant find how to move a surface a little higher to link two stairs and build a 180 deg. stairs. i think it's impossible and i just had to add a cubic object and size it as my need. is it right?
Re: Change level of a surface
thanks again. no . i can't define elevation for a surface and i think it's not possible in this version. if it's possible please tell me how can i do it.
Solution 1 - You can give all furniture objects any desired elevation. So, insert a flat box as a halfway floor and give it the desired elevation. Then, give the second staircase the same elevation as the halfway box.
Solution 2 - If you want to use a floor, do as follows: - insert a new level; - give that level an elevation that's half the height of your room; - on the bottom level insert the first stairs; - draw a room without a ceiling on the new level; - staircase two goes on the halfway level and reaches the floor of the next floor.
Success.
