Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Change level of a surface » » » » Post: Re: Change level of a surface |
Print at Aug 22, 2026, 4:32:23 PM |
| Posted by hansmex at Dec 31, 2013, 12:29:26 AM |
Re: Change level of a surface Solution 1 - You can give all furniture objects any desired elevation. So, insert a flat box as a halfway floor and give it the desired elevation. Then, give the second staircase the same elevation as the halfway box. Solution 2 - If you want to use a floor, do as follows: - insert a new level; - give that level an elevation that's half the height of your room; - on the bottom level insert the first stairs; - draw a room without a ceiling on the new level; - staircase two goes on the halfway level and reaches the floor of the next floor. Success. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Aug 22, 2026, 4:32:23 PM |
