Total posts in this thread: 99
Posts: 99   Pages: 10   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Previous Thread This topic has been viewed 387161 times and has 98 replies Next Thread
Re: Sweet Home 3D 4.2
Emmanuel,
I always use the installed version, that´s the 881 byte file.
[Oct 31, 2013, 10:01:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The installers versions still use Java 6 (information shown in About dialog), but it would be astonishing that it could provoke a bad interaction with Java 7 installed in the system. I'll check...
[Oct 31, 2013, 10:12:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
The webstart version opens every file I try without problems.
Haans
[Oct 31, 2013, 11:05:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@
Thanks for the new version!
Although the checkbox "check for updates" was enabled in my 4.1.-Version, the software did not inform me about the new release. Even hitting the "check now" button did not help. Maybe this was a bug in 4.1. ?
[Oct 31, 2013, 10:10:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
m@, if you re-read a few posts above you'll see that version 4.2 is currently on beta stage.
[Oct 31, 2013, 11:47:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal900, version 4.2 is out since yesterday evening (I posted a message in this thread, updated the main page, the History page and published an article in the blog today).
m@, the updates check feature displays a message coming from the web server. As there's always a risk to miss a last big issue, I prefer not to rush to inform every users when I release a new version, and updated this update message only tonight (thanks for recalling me anyway). It should work now. smile
[Nov 1, 2013, 12:13:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hal9000
Spain
Oops. So it was me who missed the important post. blushing And when I say "the post" I mean just the post, because I read the later post by Hansmex about the problem with the files from previous versions, but the last post I read about a release was beta 16.
Well, good to know it's out, anyway. smile
m@... I said nothing. whistling
tongue
[Edit 2 times, last edit by hal9000 at Nov 1, 2013, 1:03:39 AM]
[Nov 1, 2013, 12:57:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hans,
About the crash you reported in version 4.2, could you check whether it happens with the installer version 4.1? I suspect you didn't encounter this bug before the release of version 4.2, because you were running the Beta with Java 7 and not with Java 6 as does the installer version.
[Nov 1, 2013, 4:16:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@
Hi Emmanuel
I encounter a strange problem with the .dmg-version 4.2.: the render process stops after a few minutes and the "save" Button turns from inactive to active. It is even possible to save the uncompleted photo. But no error message appears. What could be wrong?
[Nov 1, 2013, 11:11:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
m@
Do you think it's a regression? Could you reproduce this issue more than once? If yes, could you send me the faulty file?
[Nov 1, 2013, 11:34:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
