Re: Sweet Home 3D 4.2
Hans, how do you run Sweet Home 3D? With Java Web Start or the Jar executable?
The installers versions still use Java 6 (information shown in About dialog), but it would be astonishing that it could provoke a bad interaction with Java 7 installed in the system. I'll check...
Thanks for the new version! Although the checkbox "check for updates" was enabled in my 4.1.-Version, the software did not inform me about the new release. Even hitting the "check now" button did not help. Maybe this was a bug in 4.1. ?
Spain
m@, if you re-read a few posts above you'll see that version 4.2 is currently on beta stage.
---------------------------------------- If a long walk every day were healthy, mailmen would be immortal.
m@, the updates check feature displays a message coming from the web server. As there's always a risk to miss a last big issue, I prefer not to rush to inform every users when I release a new version, and updated this update message only tonight (thanks for recalling me anyway). It should work now.
Spain
Oops. So it was me who missed the important post. And when I say "the post" I mean just the post, because I read the later post by Hansmex about the problem with the files from previous versions, but the last post I read about a release was beta 16.
Well, good to know it's out, anyway.
m@... I said nothing.
[Edit 2 times,
last edit by hal9000 at Nov 1, 2013, 1:03:39 AM]
Hans, About the crash you reported in version 4.2, could you check whether it happens with the installer version 4.1? I suspect you didn't encounter this bug before the release of version 4.2, because you were running the Beta with Java 7 and not with Java 6 as does the installer version.
