Re: Sweet Home 3D 4.2
Thanks okh for the information you sent, I fixed the bug you reported in the Beta 16.
Emmanuel,
Thank you for version 4.2. I´m afraid I found a problem using Ubuntu 12.04 and Oracle Java 7.
The program starts normally and allows me to open files created with the beta 4.2. However, when I try to open files created with an earlier version (I tried files created with 4.1 and 4.0) there´s strange behaviour: 1 - When I open a file created in v4.1 or v4.0, the program seems to close. Strangely enough the tab that indicates a program is running stays active, and when I use System Monitor, the program is shown as active as well. However, there is no way to make the program display anything. I have to use End or KIll to terminate the program. 2 - When I first open a file created with a beta of v4.2, and then open a file created with an older version, the program instance showing the v4.2 file stays active and accessible, but the program instance of the v4.1 or v4.0 file doesn´t come up and is not accessible. Again, the only way to terminate those instances is to use the End or Kill command, which of course also ends the correctly running v4.2 instance of the program.
Hans, how do you run Sweet Home 3D? With Java Web Start or the Jar executable?
The installers versions still use Java 6 (information shown in About dialog), but it would be astonishing that it could provoke a bad interaction with Java 7 installed in the system. I'll check...
