Total posts in this thread: 2
Previous Thread This topic has been viewed 4165 times and has 1 reply Next Thread
calypso2k
Problems with globalIllumination=path
Hello,
this is my first post, so hello all, and thank YOU for amazing app :)
If I use SweetHome3D.l4j.ini file with options like
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.globalIllumination=path
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.diffusedBounces=3
-Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.causticsPhotons=1000000
I have to remove sky texture, it has to be solid color otherwise render is solid black using virtual visitor, aerial view is just fine.
Second thing - my interior renders (virtual visitor) are quite dark (at day, at noon), I think walls should reflect more light, I am not talking about walls like mirrors. Is there any way to setup walls that reflect more light, so the overall render is more bright?
[Jul 26, 2013, 5:29:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Problems with globalIllumination=path
You could add a large powerful light outside in the same direction that the one of the sun, or more simply post process the computed image with an image editor to make it brighter.
In case you didn't know, causticsPhotons are not used for light reflection, but for light going through transparent materials.
[Jul 28, 2013, 11:51:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
