Noisy reflection
I have a question about the reflection on the wall. There is a wall and an object. Wall - glossy colored ceramic tile, without figures. Tiles should be self-colored and smooth, but a reflection on the wall looks like a single points of light, or as noise. I want to get a smooth reflection. How do I make a reflection without noise? Sorry for my English. Example: http://www.mediafire.com/view/sp7rc8azzx7aed6/03_copy.png
Re: Noisy reflection
The easiest way to reduce noise is to create a twice (or more) larger image and reduced it once the image is computed with an image software.
Spain
Hmm... that may serve as a workaround, but when you're rendering an HD image which takes several hours to complete, the last thing you want is to multiply the rendering time by 4.
---------------------------------------- If a long walk every day were healthy, mailmen would be immortal.
As said before, it was the easiest way. The other way would be to increase antialiasing with the following parameter passed to the JVM (see also this message):
Rendering will go slower but not as much as computing a larger image.
