Total posts in this thread: 12
Previous Thread This topic has been viewed 14454 times and has 11 replies Next Thread
connker
United Kingdom
confused Want to create an arch model
hey guys, im currently a 3d design student and im building a venue within a arch. my mate just found this program (my jaw dropped at it :O) but i am just wondering if there is a way to create an arch shape with the existing features cant seem to work out a way with the walls currently, or if there is a model that i can install already out there? biggrin my exam is next week and i would love to be able to include this within my project.
[Apr 30, 2013, 8:36:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Want to create an arch model
Conner,
1 - On the 3D models page there's an arch (zip) you can use.
2 - If that isn't what you're looking for, then you can make your own arch. Basically, you make your design in the horizontal plane, then use Export as OBJ and Import as furniture. During importing you can rotate your model 90 degrees, to give it the correct orientation.
[Apr 30, 2013, 10:25:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
perdrix52
I just downloaded the arch, but found it will not make a hole in a wall, unlike (e.g.) a door-frame.
How can I make it cut an opening please?
[Sep 24, 2013, 10:34:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
While importing the arch, check the door/window box.
Of course, you could read the User's Guide ....
[Sep 24, 2013, 11:19:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
This thread on SourceForge on Arched Doors may also be of interest.
[Sep 26, 2013, 12:52:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lightweave
I tried now to do these changes, that you suggested, but whenever I load the model it doesn't create a hole in the wall anymore. Is there something I'm missing?
[Oct 4, 2013, 12:00:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you check the door/window box in step 2 of importation?
[Oct 4, 2013, 12:19:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lightweave
Thanks! That was what I was overlooking this time. :o
Now I tested the model and it works now as OKH indicated. I upload the new version.
[Oct 4, 2013, 3:25:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yes, that works. Very nice. If it is a model you will use again, you may also want to consider using the FurnitureLibraryEditor to fix the settings (default size and door/window property).
PS - and even more door properties can be added if you so wish, see:
http://www.sweethome3d.com/support/forum/view...ad,2006_lastpage,yes#8919
[Oct 9, 2013, 10:38:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
And apparently, our efforts are now about to be rendered totally superfluous thanks to Emmanuel Puybaret's excellent programming :-)
See: http://www.sweethome3d.com/support/forum/viewthread_thread,4444
It really is quite amazing how powerful sh3d now is. Congratulations.
[Oct 9, 2013, 11:01:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
