problème le programme se ferme tout seule avec un fichier .log sur mon bureau
Bonjour, j'ai un problème avec SH3d, le programme se ferme tout seul et un fichier log s'affiche sur mon bureau, y a t-il un problème avec Java ?
le fichier est nommé " hs_err_pid5940.log "
le descriptif du fichier :
# # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x07eb2e53, pid=5940, tid=3376 # # JRE version: 7.0_11-b21 # Java VM: Java HotSpot(TM) Client VM (23.6-b04 mixed mode, sharing windows-x86 ) # Problematic frame: # C [ig4icd32.dll+0x12e53] # # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. #
--------------- T H R E A D ---------------
Current thread (0x04ffa800): JavaThread "J3D-Renderer-1" [_thread_in_native, id=3376, stack(0x09200000,0x09250000)]
EAX=0x00000000 is an unknown value EBX=0x0a968901 is an unknown value ECX=0x09f69540 is an unknown value EDX=0x08b560b8 is an unknown value ESP=0x0924eb24 is pointing into the stack for thread: 0x04ffa800 EBP=0x0001803f is an unknown value ESI=0x0a96df10 is an unknown value EDI=0x09f69540 is an unknown value
VM Mutex/Monitor currently owned by a thread: None
Heap def new generation total 157248K, used 47329K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 30% used [0x144d0000, 0x16ea5398, 0x1cd50000) from space 17472K, 25% used [0x1de60000, 0x1e2c32a8, 0x1ef70000) to space 17472K, 0% used [0x1cd50000, 0x1cd50000, 0x1de60000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12785K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514c5d8, 0x3514c600, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000)
GC Heap History (10 events): Event: 376.794 GC heap before {Heap before GC invocations=233 (full 99): def new generation total 157248K, used 145925K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 100% used [0x144d0000, 0x1cd50000, 0x1cd50000) from space 17472K, 35% used [0x1cd50000, 0x1d351598, 0x1de60000) to space 17472K, 0% used [0x1de60000, 0x1de60000, 0x1ef70000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12783K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514be58, 0x3514c000, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000) Event: 376.802 GC heap after Heap after GC invocations=234 (full 99): def new generation total 157248K, used 5905K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 0% used [0x144d0000, 0x144d0000, 0x1cd50000) from space 17472K, 33% used [0x1de60000, 0x1e424548, 0x1ef70000) to space 17472K, 0% used [0x1cd50000, 0x1cd50000, 0x1de60000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12783K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514be58, 0x3514c000, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000) } Event: 380.996 GC heap before {Heap before GC invocations=234 (full 99): def new generation total 157248K, used 145682K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 100% used [0x144d0000, 0x1cd50000, 0x1cd50000) from space 17472K, 33% used [0x1de60000, 0x1e424ad0, 0x1ef70000) to space 17472K, 0% used [0x1cd50000, 0x1cd50000, 0x1de60000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12783K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514be58, 0x3514c000, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000) Event: 381.004 GC heap after Heap after GC invocations=235 (full 99): def new generation total 157248K, used 5700K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 0% used [0x144d0000, 0x144d0000, 0x1cd50000) from space 17472K, 32% used [0x1cd50000, 0x1d2e1250, 0x1de60000) to space 17472K, 0% used [0x1de60000, 0x1de60000, 0x1ef70000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12783K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514be58, 0x3514c000, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000) } Event: 381.005 GC heap before {Heap before GC invocations=235 (full 99): def new generation total 157248K, used 11160K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 3% used [0x144d0000, 0x14a24f18, 0x1cd50000) from space 17472K, 32% used [0x1cd50000, 0x1d2e1250, 0x1de60000) to space 17472K, 0% used [0x1de60000, 0x1de60000, 0x1ef70000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12783K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514be58, 0x3514c000, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000) Event: 381.012 GC heap after Heap after GC invocations=236 (full 99): def new generation total 157248K, used 5699K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 0% used [0x144d0000, 0x144d0000, 0x1cd50000) from space 17472K, 32% used [0x1de60000, 0x1e3f0f10, 0x1ef70000) to space 17472K, 0% used [0x1cd50000, 0x1cd50000, 0x1de60000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12783K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514be58, 0x3514c000, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000) } Event: 385.218 GC heap before {Heap before GC invocations=236 (full 99): def new generation total 157248K, used 145476K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 100% used [0x144d0000, 0x1cd50000, 0x1cd50000) from space 17472K, 32% used [0x1de60000, 0x1e3f1100, 0x1ef70000) to space 17472K, 0% used [0x1cd50000, 0x1cd50000, 0x1de60000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12783K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514be88, 0x3514c000, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000) Event: 385.226 GC heap after Heap after GC invocations=237 (full 99): def new generation total 157248K, used 5736K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 0% used [0x144d0000, 0x144d0000, 0x1cd50000) from space 17472K, 32% used [0x1cd50000, 0x1d2ea1f8, 0x1de60000) to space 17472K, 0% used [0x1de60000, 0x1de60000, 0x1ef70000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12783K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514be88, 0x3514c000, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000) } Event: 399.181 GC heap before {Heap before GC invocations=237 (full 99): def new generation total 157248K, used 145513K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 100% used [0x144d0000, 0x1cd50000, 0x1cd50000) from space 17472K, 32% used [0x1cd50000, 0x1d2ea570, 0x1de60000) to space 17472K, 0% used [0x1de60000, 0x1de60000, 0x1ef70000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12785K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514c5c8, 0x3514c600, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000) Event: 399.189 GC heap after Heap after GC invocations=238 (full 99): def new generation total 157248K, used 4492K [0x144d0000, 0x1ef70000, 0x1ef70000) eden space 139776K, 0% used [0x144d0000, 0x144d0000, 0x1cd50000) from space 17472K, 25% used [0x1de60000, 0x1e2c32a8, 0x1ef70000) to space 17472K, 0% used [0x1cd50000, 0x1cd50000, 0x1de60000) tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000) the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000) compacting perm gen total 12800K, used 12785K [0x344d0000, 0x35150000, 0x384d0000) the space 12800K, 99% used [0x344d0000, 0x3514c5c8, 0x3514c600, 0x35150000) ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000) rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000) }
Deoptimization events (0 events): No events
Internal exceptions (10 events): Event: 279.352 Thread 0x0d1b9c00 Threw 0x199f2c68 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:2846 Event: 294.028 Thread 0x0d1b9c00 Threw 0x344d05b8 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\gc_interface/collectedHeap.inline.hpp:171 Event: 294.223 Thread 0x0d1b9000 Threw 0x1a427db0 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:2846 Event: 300.332 Thread 0x04ff7000 Threw 0x1a88ef80 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jni.cpp:742 Event: 317.726 Thread 0x04ff7000 Threw 0x1c5c9628 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jni.cpp:742 Event: 317.745 Thread 0x04ff7000 Threw 0x1c5d7ad0 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:1166 Event: 317.745 Thread 0x04ff7000 Threw 0x1c5d8280 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:1166 Event: 317.745 Thread 0x04ff7000 Threw 0x1c5d87c8 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:1166 Event: 317.745 Thread 0x04ff7000 Threw 0x1c5da068 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:1166 Event: 352.081 Thread 0x04ff7000 Threw 0x14c2a198 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jni.cpp:742
Events (10 events): Event: 381.005 Executing VM operation: GenCollectFull Event: 381.012 Executing VM operation: GenCollectFull done Event: 385.217 Executing VM operation: GenCollectForAllocation Event: 385.217 Executing VM operation: GenCollectForAllocation done Event: 385.218 Executing VM operation: GenCollectFull Event: 385.226 Executing VM operation: GenCollectFull done Event: 399.180 Executing VM operation: GenCollectForAllocation Event: 399.181 Executing VM operation: GenCollectForAllocation done Event: 399.181 Executing VM operation: GenCollectFull Event: 399.189 Executing VM operation: GenCollectFull done
vm_info: Java HotSpot(TM) Client VM (23.6-b04) for windows-x86 JRE (1.7.0_11-b21), built on Jan 12 2013 02:19:22 by "java_re" with unknown MS VC++:1600
Re: problème le programme se ferme tout seule avec un fichier .log sur mon bureau
J'espère que les solutions proposées dans la FAQ résoudront votre problème.
