File type .skp => .obj
Hi!
I need to use some 3d-Models that are not in obj. or in any of the type SW allows... the one I'm currently trying to import is a Sketchup-object, that is to say a .skp, which obviously wouldn't work
I was hoping somebody would know how to change the type of the file, how to convert .skp into .obj for example, without destroying the attributes of the file?
For Trimble 3D Warehouse models available only in SKP/SketchUp format, it is possible to easily convert them to DAE/Collada format by choosing File > Export > 3D Model... out of the menu in the free version of SketchUp.
Then you can import DAE/Collada files in Sweet Home 3D.
[Edit 1 times,
last edit by Puybaret at Mar 17, 2013, 2:52:00 PM]
