Total posts in this thread: 4
Previous Thread This topic has been viewed 38984 times and has 3 replies Next Thread
truffe2miel
confused File type .skp => .obj
Hi!
I need to use some 3d-Models that are not in obj. or in any of the type SW allows... the one I'm currently trying to import is a Sketchup-object, that is to say a .skp, which obviously wouldn't work sad
I was hoping somebody would know how to change the type of the file, how to convert .skp into .obj for example, without destroying the attributes of the file?
confused
Do you?
[Mar 17, 2013, 1:47:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: File type .skp => .obj
As said at the end of the 3D models page:
For Trimble 3D Warehouse models available only in SKP/SketchUp format, it is possible to easily convert them to DAE/Collada format by choosing File > Export > 3D Model... out of the menu in the free version of SketchUp.
Then you can import DAE/Collada files in Sweet Home 3D.
[Edit 1 times, last edit by Puybaret at Mar 17, 2013, 2:52:00 PM]
[Mar 17, 2013, 2:49:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
truffe2miel
Thank you very much.... should've read to the end!!
[Mar 17, 2013, 2:54:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
nigec
if you want to import your scene/object into Sketchup there a importer here:
http://www.filecluster.fr/telecharger/FluidImporter-for-SketchUp-156566.html
It works well, and works fine with the free SU
[Mar 31, 2013, 10:51:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
