Total posts in this thread: 4
Previous Thread This topic has been viewed 2311 times and has 3 replies Next Thread
robinpecha
Czech Republic
Walls from prefabricated modules
Hi, it is possible to import part of the walls?
I want to build a wooden houses from the prefabricated modules.
Module sizes are 1 x 3 m.
http://i46.tinypic.com/156amab.jpg
Thanks for the info.
[Mar 14, 2013, 11:36:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Walls from prefabricated modules
You can easily build these pieces using SH3D. Use Export as OBJ, then Import as furniture.
[Mar 14, 2013, 7:34:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
robinpecha
Czech Republic
Thank you for the reply.
But perhaps it is not possible to create a wall so that the composed of several modules?
[Mar 14, 2013, 7:54:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you use imported models, they behave as "furniture".
So, they make look like a wall, but they do not behave like wall.
Example: you cannot insert doors or windows in an imported wall segment. And you cannot give the inside of the imported wall segment a different colour or texture as the outside. That has to be done when you design the wall segments.
On the other hand, you can place wall segments next to, and on top of each other, and you will not see the difference.
[Mar 14, 2013, 9:43:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
