Total posts in this thread: 6
Previous Thread This topic has been viewed 4396 times and has 5 replies Next Thread
shet
Rendering Problem
Hello,
I have a problem with rendering, for example, transparent or semitransparent curtain. See my presentation set in the attachment.
Thanx for replies.
[Feb 23, 2013, 3:50:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shet
Re: Rendering Problem
[Feb 23, 2013, 10:26:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You should try to play with the color of the object, not only with its opacity factor.
For your information, as you'll see in this post and previous ones in the same thread, translating OpenGL transparency to SunFlow transparency (i.e. rendering engine at the two best quality levels) wasn't so easy, and it took a while to find acceptable values to render existing 3D models. Feel free to change them in the source code if needed.
[Feb 23, 2013, 10:55:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shet
For this time I Thank you. I will try.
[Feb 23, 2013, 11:03:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shet
Nothing better.
If the object is plane, there is no problem, but "wave" object with d < 1 makes me trouble. Nothing helped me. I used manual for MTL http://paulbourke.net/dataformats/mtl/ but without success. Any suggestions?
[Feb 23, 2013, 1:34:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
shet
I found no way to do that via transparency, but when i applied semitransparent texture to object, it is OK. But very hard way to render such an object for CPU :-(
[Feb 23, 2013, 5:29:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
