Total posts in this thread: 4
Previous Thread This topic has been viewed 2259 times and has 3 replies Next Thread
cleveroff
Latvia
Select items in the room
Good evening. Is it possible to select furniture in the room? When I try to do it, whole room is dragging. So I can select items only in the space without designed room.
[Dec 26, 2012, 1:53:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jasan
Re: Select items in the room
I do not fully understand your question. Hold shift and select furniture if you would like to select many furniture at the same time.
If you are using the "select area feature" it seems like SH3D also selects the floor and that could be the reason why the whole room is moving.
[Dec 26, 2012, 11:10:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Here are two tips you should use to help you select items:
- lock the base plan with the item in the Plan menu or the lock displayed at the top left corner of the plan to make rooms and walls unselectable,
- use contextual menu Select object to select one of the object where you right clicked with the mouse.
[Dec 27, 2012, 10:46:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cleveroff
Latvia
Thank you. Shift seems to be very useful key :)
[Dec 27, 2012, 4:14:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
