Print at Sep 25, 2026, 5:33:29 AM View all posts in this thread on one page
Posted by cleveroff at Dec 26, 2012, 2:53:02 PM
Select items in the room
Good evening. Is it possible to select furniture in the room? When I try to do it, whole room is dragging. So I can select items only in the space without designed room.
Posted by jasan at Dec 27, 2012, 12:10:24 AM
Re: Select items in the room
I do not fully understand your question. Hold shift and select furniture if you would like to select many furniture at the same time.
If you are using the "select area feature" it seems like SH3D also selects the floor and that could be the reason why the whole room is moving.
Posted by Puybaret at Dec 27, 2012, 11:46:54 AM
Here are two tips you should use to help you select items:
- lock the base plan with the item in the Plan menu or the lock displayed at the top left corner of the plan to make rooms and walls unselectable,
- use contextual menu Select object to select one of the object where you right clicked with the mouse.
Posted by cleveroff at Dec 27, 2012, 5:14:49 PM
Thank you. Shift seems to be very useful key :)
