can't open my saved file anymore
I worked on a file, saved it and now, 2 days later, while trying to open the file again, I get the error message " can not open file /user/.... fileName". other files, which I created the same day can be opened perfectly. version of SH3d: 3.7 / mac on an iMac with 10.7.5 / latest java 1.6.0_37. what can I do? thanks.
Re: can't open my saved file anymore
Since the version 3.7 was released only yesterday, you probably encountered the bug that was fixed in that version, but the correction can't recover corrupted files created with previous versions. Please send me your file. I'll try to fix it.
Compress it before sending it. Don't worry for my mail box, it will accept it.
I fixed most errors in your file but it wasn't due to the bug I fixed in version 3.7. It was probably an error that happened during a copy or a transfer, so you'd better try to find the original file if this is the case.
first of all many thanks! happy to have it working again (all the measurements... ) and this is/was the original file. I sync my iMac with my macBook through Wuala. and the file on the macBook is corrupted too. maybe something went wrong while syncing? ...
Italy
i downloaded your beautiful program yesterday and i've a problem while open files, too. I created a new file yesterday, and today, when i tried to re-open it, i couldn't do anymore. I tried other times but it was impossible. Please help me, thanks a lot.
If you transferred the file with a USB key or by email, maybe the file was altered and you should try to find the original file. If not, please send me your file, I'll try to fix it.
