Previous Thread This topic has been viewed 4825 times and has 13 replies Next Thread
Bug in textures?
Emmanuel,
Today I downloaded and installed SH3D 3.7 and the Texture Editor 1.0.
I made a SH3T file with a number of textures using the Editor, and imported it in SH3D. All works well, so far.
I then applied a few random textures on a box, and noticed that with some textures the box turns transparent when seen from certain angles. I checked, and found that these are PNG files. I attach the file that shows this.
I have used these textures before and never noticed this behaviour.
Attachment bug transparent texture.sh3d (909362 bytes) (Download count: 577)
[Oct 26, 2012, 4:41:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Bug in textures?
Thank you for your feedback, Hans. smile
I also noticed some weird issues with some texture images when they use transparency, and this problem was already there in version 3.1 when I added support for transparent PNGs. sad
I think it's due to OpenGL or maybe the library that calls OpenGL, so it will be almost impossible to fix, and you should use transparent PNGs only when necessary.
[Oct 26, 2012, 10:46:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gaytan
Could this have to do as well with e.g. the cylinder; when looking from it from 'Visitor' mode, it shows squared at the bottom, whilst being a round cylinder…
Rounded walls really show as 'round' at the bottom but cylinder(s) look squared at 'ground level'….
Rgrds,
Ed
[Oct 26, 2012, 12:56:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
Maybe I didn't explain well, but these textures don't use transparency as far as I can see. (I checked in Gimp.)
Still, they look transparent from certain angles.
[Oct 26, 2012, 2:45:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ed, I don't think it's the same issue as the one you described. The issue you talk about, is due to the way surface vertices and surface normals are designed in a 3D model made only of triangles. Posting an image showing what you want to explain would definitively help to remove doubts about your explanations.
Hans, the texture image applied on the bookcase defines a transparent color. Maybe this color is not actually used in the image, but the issue is that Java considers it as potentially transparent though. When removing all information about transparency, the problem you reported disappears.
[Oct 26, 2012, 4:20:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
E,
But it's the cube that's transparent...
Do I understand you incorrectly? Or maybe you me?
[Oct 26, 2012, 6:45:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Strange!?!
On my computer, the cube doesn't show any problem. sad
[Oct 26, 2012, 6:57:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gaytan
Hi Emmanuel,
Here's the link / picture. It shows clearly at the 'bottom of the cylinder', where it sits on the ground, so to speak:
http://cl.ly/image/390J2z25021e
wink
Ed
[Oct 26, 2012, 11:36:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gaytan
Hi Emmanuel,
Me again; since last screendump I played with 'extending the floor (terrace)' over the cylinder and .... now it shows round at the base:
http://cl.ly/image/0K2L0S0e290m
Typical, or ....?
Best regards,
Ed
[Oct 26, 2012, 11:43:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ed, your cylinder seems to be at lower level and/or inside a hole.
[Oct 26, 2012, 11:44:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
