Print at Sep 20, 2026, 5:22:44 PM
Posted by Puybaret at Oct 26, 2012, 4:20:13 PM
Re: Bug in textures?
Ed, I don't think it's the same issue as the one you described. The issue you talk about, is due to the way surface vertices and surface normals are designed in a 3D model made only of triangles. Posting an image showing what you want to explain would definitively help to remove doubts about your explanations.
Hans, the texture image applied on the bookcase defines a transparent color. Maybe this color is not actually used in the image, but the issue is that Java considers it as potentially transparent though. When removing all information about transparency, the problem you reported disappears.
