Hello boys, i have a problem with SH3D 3.5 on my slackware linux 13.37. I have this graphics video "Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller" and it work with "i915" module. Normaly the graphic video work correct, when i start SH3d 3.5, the 3d window it's black. This problem found with all 3.x release while with 2.x release i see the 3d image but while i work, it crash and i have this error in "dmesg":
[drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm] capturing error event; look for more information in /debug/dri/0/i915_error_state [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 179130 at 179127, next 179131) [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 220984 at 220980, next 220985) [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 239283 at 239278, next 239284) [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 22410442 at 22410438, next 22410443) [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 22417896 at 22417893, next 22417897) [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 22454750 at 22454747, next 22454751) [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 22471918 at 22471915, next 22471919) [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 22529423 at 22529420, next 22529424) [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 22597497 at 22597494, next 22597498) [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 22630567 at 22630562, next 22630568) [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung [drm:i915_wait_request] *ERROR* i915_wait_request returns -11 (awaiting 22632653 at 22632650, next 22632654)
Re: Problem 3D with SH3D 3.5
Emmett,
I'm using Ubuntu 12.04, and it works perfectly.
Under Linux: - Update the drivers of your graphic card with the latest available ones, and try to run Sweet Home 3D again. - If this update doesn't fix your problem, click on this link to run Sweet Home 3D with an older version of the Java 3D library. If it works, 3D performances and rendering won't be as good as with default Sweet Home 3D version. - If this solution still doesn't work, you may finally want to use Sweet Home 3D without 3D features, by reading the answer to the next question.
Did you try these solutions already? You could also try to do a double install, installing Ubuntu as a second choice.
brownemmett, as you can guess, I can't test Sweet Home 3D on all Linux variants available out of there, but this sounds like a problem in your graphics driver. Does a program like Art of Illusion work correctly?
Hello Puybaret, i have tried ArtofIllusion and i have similar problem. I don't see the 3d images. I have last driver of the i915. If i run "glxinfo | grep render" i see that rendering is enabled
direct rendering: Yes OpenGL renderer string: Mesa DRI Intel(R) Sandybridge Mobile x86/MMX/SSE2
Hello boys, i have install on my notebook "slackware current 64" and after installation, i have same problem. The old version was slackware 13.37 32bit and it had same problem. I think that problem is the driver of Intel Graphics or the driver is incompatible. have you any idea? Thank you boys
I have update the "mesa" driver from 7.9.2 to 7.10.2 and i resolve the problem with Opengl. Sweet Home 3D and all 3D software work correctly. Thank you boys
Great to read you found the right driver update Have fun with Sweet Home 3D!
