Total posts in this thread: 6
Previous Thread This topic has been viewed 7266 times and has 5 replies Next Thread
miguel78
Can not render or export to obj file
hi, i'm new to SH3d.
Can not render one of my project. No problems with other files.
Can not export to obj file to render with blender.
java console shows following error
Can't load texture: CLOTH_02.JPG Make sure it is located in the same server an
d directory with the model file. the loader's base path is: jar:file:C:\Users\mi
gui\Application Data\eTeks\Sweet Home 3D\work\3500-dda97bcc-c9e6-4442-8023-21e2b
e1f305e\open8802407051458218221.sweethome3d!/185/
Exception in thread "AWT-EventQueue-0 " java.lang.ArrayIndexOutOfBoundsException:
-1
at java.util.ArrayList.get(Unknown Source)
at com.eteks.sweethome3d.model.Home.clone(Unknown Source)
at com.eteks.sweethome3d.swing.PhotoPanel.startPhotoCreation(Unknown Sou
rce)
at com.eteks.sweethome3d.swing.PhotoPanel.access$000(Unknown Source)
at com.eteks.sweethome3d.swing.PhotoPanel$1.actionPerformed(Unknown Sour
ce)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Sour
ce)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Exception in thread "autoSaveTimer" java.lang.RuntimeException: java.lang.reflec
t.InvocationTargetException
at com.eteks.sweethome3d.io.AutoRecoveryManager.cloneAndSaveHomes(Unknow
n Source)
at com.eteks.sweethome3d.io.AutoRecoveryManager.access$500(Unknown Sourc
e)
at com.eteks.sweethome3d.io.AutoRecoveryManager$8.run(Unknown Source)
at java.util.TimerThread.mainLoop(Unknown Source)
at java.util.TimerThread.run(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
at java.awt.EventQueue.invokeAndWait(Unknown Source)
... 5 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: -1
at com.eteks.sweethome3d.io.AutoRecoveryManager$9.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
[Aug 5, 2012, 10:43:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can not render or export to obj file
Please send me your file.
[Aug 6, 2012, 10:19:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
miguel78
just send the project !
[Aug 8, 2012, 3:25:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I found the issue in your file. Very strangely, you had two pieces of furniture named "Bombilla Incandescente" and "aplique-pared" which didn't belong to any level. Once they were removed, it worked.
Do you use some plug-ins with your version of Sweet Home 3D?
[Aug 8, 2012, 3:07:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
miguel78
Emanuel thank you very much
like you said, there is a grouped object not belonging to any level.
I could reproduce this behavior.
This happens when I grouped two objects (incandescent light source + lamp object).
Hope this helps
sorry for my english! smile
[Aug 14, 2012, 3:14:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for the test case. smile
I fixed the bug and the correction will be available in the next version.
[Aug 14, 2012, 4:35:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
