Total posts in this thread: 5
Previous Thread This topic has been viewed 3269 times and has 4 replies Next Thread
marchenar
Argentina
How to use the applet viewer with multi-level houses?
Hello, I drew a two levels house, and I would like to know if it is any way to do the following things from the "applet viewer":
1.- Show/hide levels, or any way to see the lower level aerial view (using the aerial view I can only see the upper level covering the lower level). Using the editor I could select the level (using the tabs) and show/hide levels (using Ctrl+Shift+A and Ctrl+Alt+A), but I did find the way to do the same from the applet viewer.
2.- When I change to the virtual visitor viewer (using Space bar), the virtual visitor is in the lower level. Is there any way to move to the upper level using the applet viewer?
Thank you,
Roberto
[Jul 13, 2012, 12:48:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to use the applet viewer with multi-level houses?
The viewer supports only the space bar to switch between aerial view and virtual visit.
If you want to go to the upper level, you'll have to use home and end keys to change elevation.
[Jul 16, 2012, 5:52:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
marchenar
Argentina
sad Re: How to use the applet viewer with multi-level houses?
Hello, thanks for your response. I notice that the Home and End keys doesn't work on Applet Viewer, have you any other idea how to change the level using the Applet Viewer?
[Jul 18, 2012, 8:08:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Austinic
Hello, srry guyz to interfere, but I am new here, so wat is applet viewer?
THX :)
[Aug 20, 2012, 11:08:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
marchenar
Argentina
Hello Austinic,
The Applet Viewer is just an applet written in Java to view SH3D designs from a web browser.
Regards,
Roberto
[Aug 20, 2012, 3:04:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
