Print at Aug 21, 2026, 12:41:19 PM
Posted by marchenar at Jul 13, 2012, 2:48:39 PM
How to use the applet viewer with multi-level houses?
Hello, I drew a two levels house, and I would like to know if it is any way to do the following things from the "applet viewer":
1.- Show/hide levels, or any way to see the lower level aerial view (using the aerial view I can only see the upper level covering the lower level). Using the editor I could select the level (using the tabs) and show/hide levels (using Ctrl+Shift+A and Ctrl+Alt+A), but I did find the way to do the same from the applet viewer.
2.- When I change to the virtual visitor viewer (using Space bar), the virtual visitor is in the lower level. Is there any way to move to the upper level using the applet viewer?
Thank you,
Roberto
